CR Card
This card specifies the orientation of a 3D anisotropic medium.
In the Home tab, in the Define group, click the   Media icon. From the drop-down list select the  Orientation (CR) icon.
Figure 1. The CR - Specify orientation for anisotropic medium (3D) dialog.
Parameters:
Affect all structures with label
Regions with the specified labels will be affected.
Coordinate system
The coordinate system in which the 3D anisotropic medium orientation is defined.
Position (coordinate)
The X, Y and Z coordinates defining the origin of the workplane are entered in m. This value is affected by the scale factor of the SF card (if used).
Rotation about the axes
The angles with which the workplane is rotated around the X, Y and Z axes are entered.
