Non-Conducting Element
This option defines a non-conducting fibre used as spacing elements and for additional strength to cables.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_cd7.png)
Figure 1. The CD - Cable cross section definition dialog.
Parameters:
- Cross section label
- The label of the cross section.
- Material label
- The label of the dielectric (as defined in the DI card) to be used for the non-conducting fibre.
- Radius
- The radius of the non-conducting fibre.
- Cable per-unit-length parameters accuracy
- The Cable per-unit-length parameters accuracy can be increased from Normal (default) to High or Very high.
