Change the length of time that can be taken while requeueing a job.
When jobs are preempted via requeueing, the requeue can fail if the job being
preempted takes longer than the allowed timeout. The time for requeueing includes
post-processing such as staging files out, deleting files, and changing the job’s state.
Change how long the process of requeueing a job is allowed to take. Node failure,
manual requeue
Click the Configure tab.
Choose the HPC to configure.
Click Server Settings from the
PBS Professional menu located on the left-hand side of the
web page.
Click located in the upper right-hand corner of the web page.
Enable the Display Advanced Settings check box.
Click located to the right of Job Requeue
Timeout.
For Job Requeue Timeout, enter the job requeue timeout
duration.
The duration can be entered as an integer in seconds or in the format:
[[HH:]MM:]SS[.milliseconds]. Default is 45 seconds.
Click to save the change.
