Configure Job History
Configure the Workload Manager to keep job history for jobs which have finished execution, were deleted, or were moved to another server.
  1. Click the Configure tab.
  2. Choose the HPC to configure.
    Choose an HPC
    Figure 1. Choose an HPC
  3. Click Server Settings from the PBS Professional menu located on the left-hand side of the web page.
  4. Click located to the right of Job History.
  5. Choose one of the following options:
    • Enable the Job History check box to retain job history information for any jobs that are queued or running.
    • Disable the Job History check box to delete all job history information.
  6. Click to save the change.
  7. Click located to the right of Job History Duration.
  8. For Job History Duration, enter the length of time that job history is to be preserved.
    Note: Enter a value only when job history is being enabled.
    The duration can be entered as an integer in seconds or in the format: [[HH:]MM:]SS[.milliseconds]. Default is two weeks.
  9. Click to save the change.
