Pick Point Info
Obtain numeric results at one or more points on the model surface.
  1. In the Project Tree, select the Results branch under the desired analysis.
  2. In the Results window, select the Pick info tab.
  3. Select a point on the model.
    A label is displayed for the chosen point. The point is also listed in the dialog. You can select multiple points.
  4. Select a point in the dialog to highlight a point label.
    Tip: You can select multiple points with Control or Shift.
  5. Click to remove a point from the list in the dialog.
