Run Analysis
Solve the analysis or study.
  1. On the Project Tree, click on the Analysis Workbench.
  2. Click (Solve).
  3. In the Solve dialog, select the check boxes to indicate which analyses or studies you want to run.
  4. Click Solve.
    After the solver has finished, the Results window appears. You can review all results from this dialog. A Results branch also appears in the Analyses panel.
