View Geometric Non-linear Results
View displacement results for geometric non-linear analysis.
With linear analysis, displacements are small. Deformed shapes are scaled so that the deformation can be visualized. With geometric non-linear displacement can be significant. You may want to view them in true scale.
- In the Project Tree, click the Results branch for the geometric non-linear analysis.
To view results in true scale, on the Deformation panel, select the
True deformation check box.
View Safety factors
to ensure the material has not yielded (Safety factor less than 1.0).
Remember: The analytic assumption in geometric non-linear is large deflections/rotations but small strains. The material properties are still assumed to be linear.
