Move Faces
Translate, rotate, copy, or extend features.
Move Features
Move holes, pockets, and surface features.
- All features being moved must be located on the same part.
- While translating or rotating, selected objects snap to discrete positions along the axes and compass that appear with the Move Faces tool, or to snap points on other objects. You can temporarily disable snapping by holding down the Alt key.
- Double-click a manipulator or hold down Shift while dragging to reposition or reorient the tool. This is useful if you want to change the center of rotation.
- Use the icons on the microdialog to align the Move Faces tool to the selected feature's local or global axes.
Copy Features
Copy holes, pockets, and surface features.
Extend Features
Extend holes, pockets, and surface features that include multiple faces.
Graphic Manipulators
1D translation along an axis
2D translation within a plane
2D rotation within a plane
3D translation
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Temporarily disable snapping | Alt |
| Add to or remove from the selection | Ctrl |
| Copy a selected feature | Ctrl+drag the graphic manipulator |
| Reposition the tool or change its orientation | Shift |
| Reposition the tool or change its orientation | Double-click the graphic manipulator |
| Chain select faces |
| Exit editing mode | Right-click |
| Exit the tool | Right-click and mouse through the check mark to exit, or double-right-click. |
