Scale Parts
Resize parts in your model, which is useful when working with an imported model that is associated with a different default unit system.
By default, parts are scaled around the global origin. However, you can select any snap point to make it the scaling center.
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Add to or remove from the selection | Ctrl |
| Select a point on a face as the scaling center | Shift |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
