Boolean Parts
Create a new part by using one set of solids to edit another set of solids.
The Boolean tools work on both geometry and mesh parts.
Combine Parts
Combine two individual objects or two sets of objects.
Subtract Parts
Carve out one set of solid objects from another set of solid objects.
- Targets are the set of objects being carved.
- Tools are the set of objects doing the carving.
Intersect Parts
Retain only the intersecting portions of two sets of solid objects.
- Targets are the first set of objects.
- Tools are the second set of objects.
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Select Tools | Tab |
| Add to or remove from the selection | Ctrl |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
