Mirror Parts
Mirror parts across a symmetry plane.
- To reposition the mirror plane using the Move tool, click
. - To align the mirrored object to the x-, y-, or z-axis, click
. - To merge two coincident faces, box select the faces before opening the Mirror tool. This technique works well with mirrored parts.
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Add to or remove from the selection | Ctrl |
| Exit tool | Right-click and mouse through the check mark to exit, or double-right-click. |
