Midsurface
Extract the midsurface or side faces of thin solids. For surfaces, determine where the surface is represented by defining a thicknes direction.
Replacing parts with midsurfaces yields better results while increasing speed when running an analysis or optimization. This tool cannot be used on T-sections or similar variable thickness geometry.
