Cut, Copy, and Paste
Cut, copy, and paste objects using standard keyboard shortcuts, the context menu, or the Edit menu.
| To | Do this | Note |
| Cut |
| Copy |
You can copy an object by holding down Ctrl as you drag it. (This only works if you have Move selected in the Preference dialog under Modeling Space.) |
| Paste |
The copied object is pasted on top of the original object. Press M to use the Move tool to move the copied object. |
| Paste Instance | Right-click, and then click Paste Instance. | An instance creates a copy of the part that is linked to the original so that whenever one is updated, the other is automatically updated as well. |
