/PARITH
Engine Keyword Turns the parallel arithmetic ON/OFF.
/PARITH/Keyword2
| Field | Content | SI Unit Example |
| Keyword2 |
- The default value is defined by Radioss Starter (Iparith flag of Radioss Starter /ANALY) for the first Engine run or by the value of the previous run.
- If this option is ON, the same numerical results will be obtained whatever the number of processors. This result is not guaranteed in case of incompatible kinematic conditions in the model.
- The previous run must be PARITH=ON in order to use PARITH=ON for the current run in case of multiple Radioss Engine runs.
- /PARITH/ON is not available for Implicit Analysis.
