/NEGVOL
Engine Keyword Solid element control for elements with negative volumes. Switch to small strain formulation or stop the run a solid elements volume becomes negative.
/NEGVOL/Keyword2
| Field | Content | SI Unit Example |
| Keyword2 |
- By default, when the volume of a solid element becomes negative, the element is changed to a small strain formulation and the simulation continues. See /PROP/TYPE14 (SOLID) comments for more details about the switch to small strain.
