/OUTP
Engine Keyword Write ASCII formatted output files.
/OUTP/Keyword2/Keyword3/Keyword4
| Data | Description | SI Unit Example |
| Keyword2 | Refer to ASCII Output File (STY-File). | |
| Keyword3 | Refer to ASCII Output Files (STY-File) | |
| Keyword4 | Refer to ASCII Output Files (STY-File) |
- Table of available functionalities for
/OUTP:
Keyword2 Keyword3 Keyword4 DT VECT VEL, DIS, ACC, CONT, FINT, FEXT, FOPT, VROT, PCONT NODA DT, DMAS, DINER ELEM OFF, EPSP, ENER, VONM, HOUR, SLEN, USER1, USER2, USER3, USER4, USER5 BRIC OFF, EPSP, ENER, DENS, TEMP, P, VONM, HOUR, USER1, USER2, USER3, USER4, USER5, STRES STRAI, STRES, USERS FULL SHEL OFF, EPSP, HOUR, ENER, THIC, VONM, USER1, USER2, USER3, USER4, USER5 USRii FULL USERS FULL STRES, STRAI, EPSD0 MEMB, BEND, UPPER, LOWER, FULL TRUS OFF, EPSP SPRI OFF, FULL BEAM OFF, EPSP SPH OFF, EPSP, ENER, DENS, TEMP, P, VONM, STRES, SLEN, USER1, USER2, USER3, USER4, USER5 STRES FULL Output for /OUTP:- DT
- Nodal time step
- VEL
- For nodal translational
- DIS
- Displacements
- ACC
- Accelerations
- CONT
- Contact forces
- FINT
- Internal forces
- FEXT
- External forces
- FOPT
- Forces and moments for rigid bodies, rigid walls and sections
- VROT
- For nodal rotational velocities
- PCONT
- Contact pressure animation vector
- DMAS
- Mass variation (see time step control /DT/NODA/Keyword3/Iflag)
- DINER
- Output of added inertia per nodes
- OFF
- Output element status. In the sty file it displays:
- 0
- Deleted element
- 1
- Active element
- 2
- Element switched to Small strain formulation.
- -1
- Element in standby (for example: belonging to a rigid body)
- EPSP
- Solid plastic strain
- ENER
- Solid internal energy
- VONM
- von Mises stress
- HOUR
- Hourglass energy
- SLEN
- Current smoothing length value
- USER1, USER2, USER3, USER4, USER5
- Output user variables 1 through 5 in user law
- USRii
- Only one user variable number ii is output.
- USERS
- Output all users variables in user material
- DENS
- Solid density
- TEMP
- Nodal temperature
- P
- Nodal pressure
- STRES
- Stress tensor
- STRAI
- Strain tensor
- FULL
- Strain or stress tensor
- MEMB
- Membrane
- BEND
- Bending
- UPPER
- Upper layer
- LOWER
- Lower layer
- The OUTP files are named according to Radioss Starter Input /IOFLAG.
