/OUTPUT/LSENSOR
Engine Keyword An outp file is written each time a sensor in the defined list is activated.
/OUTPUT/LSENSOR
sensor_IDisensor_ID2 ... sensor_IDn
Data | Description | SI Unit Example |
sensor_IDi | Sensor identifier (an arbitrary number of sensors which can be written on more than one line) |
