/REPORT
Engine Keyword Creates an HTML report or HyperView session file report of the simulation.
/REPORT/Keyword2
| Field | Content | SI Unit Example |
| Keyword2 |
- For MVW output, animation and time history output is required. The animation output can be /ANIM or /H3D. The time history output can be /TFILE or /ABF. If both types of output are requested, then the /ANIM and /TFILE will be used.
