/ANIM/GPS/STRAIN/TENS
Engine Keyword Generates animation files containing averaged grip point strain data calculated by bilinear extrapolation using shape functions from the integration point results. The average value at each node is calculated by each element which connected to this node.
  1. The strain of the corner node is computed using bilinear extrapolation (use shape function) from strain at integration points of each element which are connected to this node.
  2. For thick shell properties, bilinear extrapolation is computed using integration points of upper and lower layers.
  3. This keyword is for the moment only available with solids element with /PROP/TYPE6 (SOL_ORTH), /PROP/TYPE14 (SOLID), /PROP/TYPE20 (TSHELL), /PROP/TYPE21 (TSH_ORTH) and /PROP/TYPE22 (TSH_COMP).
