/ANIM/GPS2
Engine Keyword Generates animation files containing volume based averaged GPS data, which is done by the relative element volumes (connected to same node use Vi/V total).
/ANIM/GPS2/Keyword3
Field | Content | SI Unit Example |
Keyword3 | GPS data type:
- /ANIM/GPS2 works only with constant stress element (8 node brick element with one point integration and TETRA4).
- The stress of corner node is extrapolated from stress at integration point.
