/ALE/GRID/SPRING
Engine Keyword With this keyword it is possible to modify grid formulation parameters which initially be set in Starter keyword /ALE/GRID/SPRING. (Altair bar method for grid velocity computation).
/ALE/GRID/SPRING
Vmin
| Field | Content | SI Unit Example |
| Typical time
step. (Real) |
| Nonlinearity
factor. Range: [0;1] (Real) |
| Damping
coefficient. (Real) |
| Shear scale
factor. (Real) |
| Vmin | Minimum volume for element
deletion. (Real) |
- For more
details, refer to ALE Grid Calculation in the
User Guide and /ALE/GRID/SPRING in the Starter
Reference Guide.
As of v12.0.210, /ALE/2 was replaced by /ALE/GRID/SPRING.
- The must be greater than the actual time step used in simulation.
- The
is used to prevent the time step from dropping due to
element collapse.
= 1 means no nonlinear effects
0 < < 1 means less weight is given to elements that do not collapse.
- Default values are taken from a previous run.
