/ALE/OFF
Engine Keyword Deactivates the ALE / EULER parts that are listed.
/ALE/OFF
part_ID1
part_ID2
part_IDN
part_ID1 part_ID2 … part_IDN |
Part IDs of parts to
be deactivated. Only one part can be listed, per line. |
- By default, all parts are active.
- The ALE calculation for the listed parts can be turned off which saves computation time, when using this option.
- Parts can be reactivated in a new Engine file by using /ALE/ON for the specified IDs.
