/ALE/ON
Engine Keyword Activates the ALE / EULER parts that are listed.
/ALE/ON
part_ID1
part_ID2
part_IDN
part_ID1
part_ID2
part_IDN
Part IDs of parts to be activated.
Only one part can be listed, per line.
  1. By default, all parts are active.
  2. Only needed if specified parts were previously set to OFF (/ALE/OFF) in a previous Radioss run.
