/ALE/GRID/DONEA
Engine Keyword With this keyword it is possible to modify grid formulation parameters, which initially were set in Starter keyword /ALE/GRID/DONEA.
/ALE/GRID/DONEA
α Fscalex Fscaley Fscalez Vmin
| Field | Content | SI Unit Example |
| α | Coefficient in DONEA's
formula for grid velocity calculation. (Real) |
| Grid velocity limitation
factor W <
V. (Real) |
| Fscalex | X grid velocity scale
factor. (Real) |
| Fscaley | Y grid velocity scale
factor. (Real) |
| Fscalez | Z grid velocity scale
factor. (Real) |
| Vmin | Minimum volume for element
deletion. (Real) |
- For more
details, refer to ALE Grid Calculation in the
User Guide and /ALE/GRID/DONEA in the Starter
Reference Guide.
As of v12.0.210, /ALE/0 was replaced by /ALE/GRID/DONEA.
- Default values are taken from a previous run.
