Model ElementThe
GCON element is used to specify a user defined general constraint.
Your constraint equations may involve position as well as velocity measures of the system.
Although MotionSolve provides a large set of constraints to
choose from (see JOINT), there are situations that require non-standard
constraints.
For example, the constraint that a wheel rolls without slipping is a non-holonomic constraint that can be modeled using the GCON element.
Attribute Summary
Name |
Property |
Modifiable by
command? |
Designable? |
id |
Int
NO |
label |
Str
Yes |
function |
Function ("GCOSUB") |
Yes |
routine |
Routine () |
active |
Bool
Yes |
virtual |
Bool () |
Yes |
Usage
Gcon (function=userString, optional_attributes)
Attributes
- function
- String
- An expression (that will be set to zero) defining the general
constraint.
- OR
- The list of parameters that are passed from the data file to the
user-defined subroutine, GCOSUB.
- The function attribute is mandatory
- i
- Reference to an existing Marker object.
- Specifies the marker that extracts the reaction force from the general
constraint.
- The i attribute is optional. When it is not
specified, you cannot obtain any reaction forces from the
GCON.
- id
- Integer
- Specifies the element identification number. This number must be unique
among all the GCON objects in the model.
- This attribute is optional. MotionSolve will
automatically create an ID when one is not specified.
- Range of values: id > 0
- label
- String
- Specifies the name of the GCON object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
- routine
- String or a pointer to a Python function.
- Specifies an alternative name for the user subroutine.
- The attribute routine is optional.
- When function is specified, but
routine is not, routine
defaults to GCOSUB.
- active
- Bool
- Select one from True or False.
- True indicates that the element is active in
the model and it affects the behavior of the system
- False indicates that the element is inactive in
the model and it does not affect the behavior of the system. It
is almost as if the entity was removed from the model, of course
with the exception that can be turned "ON" when desirable.
- The attribute active is optional. When not specified,
active defaults to True.
- virtual
- Boolean
- Defines whether the constraint is virtual or regular. Select
"TRUE" or "FALSE".
- “TRUE” indicates that the constraint is
implemented as a virtual constraint.
- “FALSE” indicates that the constraint is
implemented as a regular algebraic constraint.
Optional. When not specified, virtual
defaults to “FALSE”. For a more detailed
explanation about virtual, see Constraint: Joint.
Three GCONs that together are equivalent to a spherical
joint.
# Get the ids of the I and J markers
iid = imrkr.id
jid = jmrkr.id
# Create the expression strings
strx = "dx({i},{j})".format(i=iid, j=jid)
stry = "dy({i},{j})".format(i=iid, j=jid)
strz = "dz({i},{j})".format(i=iid, j=jid)
# Define the 3 GCONS: DX(I,J)=0, DY(I,J)=0, DZ(I,J)=0
gx = Gcon (function=strx, i=imrkr, label="X-Constraint")
gy = Gcon (function stry, i-imrkr, label="Y-Constraint")
gz = Gcon (function=strz, i=imrkr, label="Z-Constraint")
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
- For a more detailed explanation about Gcon, see
Constraint: General.
- For a more detailed explanation about virtual, see
Constraint: Joint.
