Contact
Model ElementContact defines a 3-D contact force between geometries on two rigid bodies.
Class Name
Contact
Each body is characterized by a set of one or more geometries. Whenever any geometry on the first body penetrates any geometry on the second body, a contact normal and frictional force are generated. The normal force tends to repulse motion along the common normal at the contact point. The frictional force tends to oppose relative sliding velocity at the contact point. The contact force vanishes when the geometries no longer intersect.
Attribute Summary
Name | Property | Modifiable by Command? | Designable? |
id | Int () | ||
label | Str () | Yes | |
igeom | Reference (Graphics, count=0) | ||
jgeom | Reference (Graphics, count=0) | ||
iflip_geometry | Reference (Graphics) | ||
jflip_geometry | Reference (Graphics) | ||
type | Enum ("NONE IMPACT POISSON VOLUME USER") | ||
stiffness | Double (0.0) | Yes | FD Only |
exponent | Double (1.5) | Yes | FD Only |
damping | Double (0.0) | Yes | FD Only |
dmax | Double (0.0) | Yes | FD Only |
penalty | Double (0.1) | Yes | FD Only |
restitution_coefficient | Double (0.0) | Yes | FD Only |
coulomb_friction | Enum ("ON OFF DYNAMICS_ONLY") | ||
mu_static | Double (0.0) | Yes | FD Only |
mu_dynamic | Double (0.0) | Yes | FD Only |
stiction_transition_velocity | Double (1E-3) | Yes | FD Only |
friction_transition_velocity | Double (1E-3) | Yes | FD Only |
i_elastic_modulus | Double (0.0) | Yes | FD Only |
i_layer_depth | Double (1.0) | Yes | FD Only |
j_elastic_modulus | Double (0.0) | FD Only | |
j_layer_depth | Double (1) | FD Only | |
master_surface | Enum ("AUTO I J IANDJ", default="AUTO") | Yes | |
collision_engine | Enum ("AUTO OPCODE PCM PARASOLID", default="AUTO") | Yes | |
normal_routine | Routine () | ||
friction_routine | Routine () | ||
friction_function | Function () | ||
normal_function | Function () | ||
active | Bool () | Yes |
Usage
- type = "IMPACT"
- type = "VOLUME"
- type = "POISSON"
- type = "USER"
Contact also supports some optional parameters that are independent of the choice of the normal force. You may specify any combination of these.
- Coulomb friction
- Your own custom friction model
# Type = "IMPACT"
Contact (type="IMPACT", igeom=list, jgeom=list, stiffness=Double, exponent=Double, damping=Double, dmax=Double, optional_attributes)
# Type = "Volume"
Contact (type="VOLUME", igeom=list, jgeom=list, i_elastic_modulus=Double, i_layer_depth=Double, j_elastic_modulus=Double, j_layer_depth=Double, exponent=Double, damping=Double, optional_attributes)
# Type = "POISSON"
Contact (type="POISSON", igeom=list, jgeom=list, penalty=Double, normal_trans_vel=Double, restitution_coefficient=Double, optional_attributes)
# Type = "USER"
Contact (type="USER", igeom=list, jgeom=list, normal_routine=String or Python function pointer, normal_function=userString, optional_attributes)
- Attributes
- type
- String "IMPACT"
- igeom
- List of Graphics objects.
- jgeom
- stiffness
- Double
- damping
- Double
- exponent
- Double
- dmax
- Double
- type
- String "VOLUME"
- igeom
- jgeom
- i_elastic_modulus
- Double
- i_layer_depth
- Double
- j_elastic_modulus
- Double
- j_layer_depth
- Double
- EXPONENT
- Double
- damping
- Double
- type
- String "POISSON"
- igeom
- jgeom
- penalty
- Double
- restitution_coef
- Double
- normal_trans_vel
- Double
- TYPE
- String "USER"
- IGEOM
- JGEOM
- normal_function
- String
- normal_routine
- String or a pointer to a Python function.
- id
- Integer
- label
- String
- master_surface
- String. Choose one from: "I", "J", "IANDJ", "AUTO"
- active
- Bool
Optional friction force specification These can be used with all normal force models
There are two options: Using the built-in friction model or using your own custom friction model. You can only select one of the two.
- coulomb_friction
- String. Choose one from: "ON", "OFF", "DYNAMICONLY", "USERCFF"
- mu_static
- Double
- mu_dynamic
- Double
- stiction_transition_velocity
- Double
- friction_transition_velocity
- Double
Using your own custom friction model
- friction_function
- String
- friction_routine
- Create a Contact object with the properties shown
below:
<Force_Contact id = "2" num_i_graphics = "1" i_graphics_id = "93" num_j_graphics = "1" j_graphics_id = "73" cnf_type = "POISSON" penalty = "1E6" restitution_coef = "0.52" cff_type = "COULOMB_ON" mu_static = "0.08" mu_dynamic = "0.06" stiction_trans_vel = "0.005" friction_trans_vel = "0.01" />
Equivalent Pythoncontact1 = Contact (type="POISSON", igeom=[gra93], jgeom=[gra73], penalty=1E6, restitution_coefficient=0.52, coulomb_friction="ON", mu_static=0.08, mu_dynamic=0.06, stiction_transition_velocity=0.005, friction_transition_velocity=0.01)
- See Properties for an explanation about what properties are, why they are used, and how you can extend these.
- For a more detailed explanation about Contact, see the Comments in Force: Contact model statements.
