udfPrim()
Determine whether this the primary processor/subdomain.
primary = udfPrim( udfHd ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
primary (integer)
The return value primary is a Flag indicating whether or not this is the primary processor:
0
No, this is not the primary processor.
1
Yes, this is the primary processor.
This routine determines if the current processor/subdomain is the primary one. For example,
Integer primary ;
if ( primary == 1 ) {
   /* possible global calculation */
} else {
   /* other processors */
This routine expects a valid udfHd.
