udfGetNumUsrVals()
Return the number of user values supplied in the input file.
nUsrVals = udfGetNumUsrVals( udfHd ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
nUsrVals (integer)
The number of user values given in the input file is returned as an integer.
This routine returns the number of user values supplied in the input file. It is most useful when the number of parameters is not know a priori, such as for an interpolated curve fit. For example,
Integer nUsrVals ;
Integer i ;
Real x, y ;
Real* usrVals ;
usrVals = udfGetUsrVals( udfHd ) ;
for ( i = 0 ; i < nUsrVals ; i+=2 ) {
    x = usrVals[i] ;
    y = usrVals[i+1] ;
This routine expects a valid udfHd.
