udfGetUsrVals()
Return the array of user-supplied values.
usrVals = udfGetUsrVals( udfHd ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
usrVals (real)
The return value is a pointer to one-dimensional real array of user values as given in the input file. This array has udfGetNumUsrVals() entries.
This routine returns the real array of user-given parameters. The order of the parameters within the array is the same as in the input file. For example,
Real* usrVals ;
Real amp, omega ;
udfCheckNumUsrVals( udfHd, 2 ) ;
amp = usrVals[0] ;
omega = usrVals[1] ;
This routine expects a valid udfHd.
