udfFirstCall()
Determine whether this the first time a user-defined function is called.
firstCall = udfFirstCall( udfHd ) ;
AcuSolve User-Defined Function Basic
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
firstCall (integer)
The return value is a flag indicating whether or not this is the first time this user function is called:
0
No, this is not the first time.
1
Yes, this is the first time.
This routine determines if this is the first time a specified user-defined function is called. For example,
Integer firstCall ;
 if ( firstCall == 1 ) {
    /* possible initialization */
} else {
    /* the rest of the time */
This routine expects a valid udfHd.
