Volume Mesh Attributes
Every geometric model in AcuConsole contains one or more volume groups. The meshing of each of these volumes can be customized using the volume mesh parameters.
If Volume Mesh attributes are not specified for any of the volumes then the global mesh attributes will be applied for such volumes.
