Surface Mesh Attributes
Similar to volumes, meshing of the surfaces can also be customized by using Surface Mesh Attributes.
If Surface Mesh Attributes are not specified for any surface group, mesh attributes for that surface will be inherited from its parent volume group or the global mesh attributes. In the event that all three mesh attributes are specified (global, parent volume and surface) AcuConsole uses the smallest of the three values.
