AcuPrep
AcuPrep is the pre-processing module of AcuSolve.
Figure 1. AcuPrep Log
View new features for AcuSolve 2021.
AcuSolve is a leading general purpose CFD solver that is capable of solving the most demanding industrial and scientific applications.
Discover AcuSolve functionality with interactive tutorials.
Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
This section gives a brief description of a general workflow of a typical CFD process. It describes in short the problem description, pre-processing, solving and post-processing aspects of a CFD workflow.
This section details the several sub-categories of pre-processing in AcuSolve, including the use of user interface, solver parameters, model parameters and mesh generation.
This section gives details on using the user interface of AcuSolve by describing several groupings of the parameters available for pre-processing.
This section details the geometry parameters such as geometry import and graphics window controls. It also involves discussion on boundary condition types, volume and surface parameters available in AcuSolve.
This section details a brief overview of meshing aspects in general and then provides various meshing attributes available in AcuConsole. This section also provides details on meshing process in AcuConsole.
This section details the AcuSolve launch settings, input file structure, checking the compatibility of the parameters using AcuPrep, parallel processing model, various solution files generated by AcuSolve and the .log file structure.
After meshing the model and setting the boundary conditions the model setup is ready for solving.
AcuConsole is the graphical user interface (GUI) wrapper for the AcuSolve solver.
As an alternative to the GUI based launch of AcuSolve, once you have the input file and mesh files (MESH.DIR) the AcuSolve solver can be launched in batch process from the AcuSolve command prompt.
AcuSolve is optimized for parallel processing on clusters.
During the solving process AcuSolve writes the relevant solution files to a folder named as ACUSIM.DIR.
During the solution process AcuSolve writes out the information to the .log file with the .log extension.
This section details the post-processing tools of AcuSolve, namely AcuProbe, which gives graphical representation of parameters and AcuFieldView, which gives the detailed description of simulations, such as plots and animations.
This section details the various tools and utilities available in AcuSolve that make the solver user-friendly.
Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy of AcuSolve results.
AcuSolve command descriptions and corresponding examples.
AcuSolve utility programs covering preparatory and post-processing as well as user-defined functions and utility scripts.
Customization of AcuSolve allowing you to customize certain capabilities of the solver.
Instruction of the mesh generation capability in AcuConsole, a GUI based pre-processor for AcuSolve.
Customization of AcuConsole allowing you to improve your particular workflow.
Commands of AcuTrace, a particle tracer that runs as a post-processor to or a co-processor with AcuSolve.
Instructions to define additional solution quantities of AcuTrace called user equations.
Usage of AcuFieldView, an OEM version of Intelligent Light’s FieldView post-processing software.
Instruction of the AcuReport tool, a standalone post-processor batch tool used to generate a report from an AcuSolve solution database.
