AcuSolve Solution Files
During the solving process AcuSolve writes the relevant solution files to a folder named as ACUSIM.DIR.
Depending on the nodal and element output parameters corresponding solution files are written to the disk. The post-processing of the solution in AcuFieldView requires access to the files in ACUSIM.DIR.
