SURFACE_TENSION_MODEL
Specifies a surface tension model for free surfaces.
AcuSolve Command
SURFACE_TENSTION_MODEL("name") {parameters...}
Qualifier
User-given name.
- type (enumerated) [=none]
- Type of the surface tension.
- constant or const
- Constant surface tension. Requires surface_tension.
- piecewise_linear or linear
- Piecewise linear curve fit. Requires curve_fit_values and curve_fit_variable.
- cubic_spline or spline
- Cubic spline curve fit. Requires curve_fit_values and curve_fit_variable.
- user_function or user
- User-defined function. Requires user_function, user_values and user_strings.
- surface_tension (real) >=0 [=0]
- Constant value of the surface tension. Used with constant type.
- curve_fit_values or curve_values (array) [={0,0}]
- A two-column array of independent-variable/surface tension data values. Used with piecewise_linear and cubic_spline types.
- curve_fit_variable or curve_var (enumerated) [=temperature]
- Independent variable of the curve fit. Used with piecewise_linear and
cubic_spline types.
- temperature or temp
- Temperature.
- species_1 or spec1
- Species 1.
- species_2 or spec2
- Species 2.
- species_3 or spec3
- Species 3.
- species_4 or spec4
- Species 4.
- species_5 or spec5
- Species 5.
- species_6 or spec6
- Species 6.
- species_7 or spec7
- Species 7.
- species_8 or spec8
- Species 8.
- species_9 or spec9
- Species 9.
- user_function or user (string) [no default]
- Name of the user-defined function. Used with user_function type.
- user_values (array) [={}]
- Array of values to be passed to the user-defined function. Used with user_function type.
- user_strings (list) [={}]
- Array of strings to be passed to the user-defined function. Used with user_function type.
- multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the viscosity. If none, no scaling is performed.
is the surface
gradient, and
is
the surface tension defined by this command. The formulation used in AcuSolve removes the necessity of computing the surface curvature and
the surface gradient of the surface tension through an integration by parts procedure.
However, the contact angle then explicitly appears, which is modeled separately. See the
CONTACT_ANGLE_MODEL command. For example, a constant surface tension
may be defined
by:SURFACE_TENSION_MODEL( "air/water" ) {
type = constant
surface_tension = 0.07
}SIMPLE_BOUNDARY_CONDITION( "free surface" ) {
surfaces = Read( "free_surface.ebc" )
shape = three_node_triangle
element_set = "water"
type = free_surface
surface_tension_model = "water/air"
contact_angle_model = "water/air @ smooth aluminum"
}FREE_SURFACE( "free surface" ) {
surfaces = Read( "free_surface.ebs" )
}SURFACE_TENSION_MODEL( "curve fit surface tension model" ) {
type = piecewise_linear
curve_fit_values = { 273, 0.07 ;
323, 0.07 ;
373, 0.06 ;
423, 0.05 ; }
curve_fit_variable = temperature
}defines surface tension as a function of temperature. In general, the problem must contain the variable defined by curve_fit_variable. The curve_fit_values parameter is a two-column array corresponding to the independent variable and the surface tension values. The independent variable values must be in ascending order. The limit point values of the curve fit are used when curve_fit_variable falls outside of the curve fit limits.
273 0.07
323 0.07
373 0.06
423 0.05SURFACE_TENSION_MODEL( "curve fit surface tension model" ) {
curve_fit_values = Read( "surface_tension.fit" )
}A surface tension model of type user_function may be used to model more complex behaviors; see the AcuSolve User-Defined Functions Manual for a detailed description of user-defined functions.
MULTIPLIER_FUNCTION( "ramped" ) {
curve_fit_values = { 1, 0.1 ; 10, 1 }
curve_fit_variable = time_step
