POROSITY_MODEL
Specifies a porosity model for the flow equation.
AcuSolve Command
POROSITY_MODEL("name") {parameters...}
Qualifier
User-given name.
- type (enumerated) [=none]
- Type of the porosity model.
- none
- No porosity.
- constant or const
- Darcy-Forchheimer porosity model. Requires permeability, darcy_coefficient, forchheimer_coefficient and permeability_direction.
- porosity (real) >0 <=1 [=1]
- Porosity value.
- permeability_type (enumerated) [=cartesian]
- Permeability type.
- cartesian
- Use Cartesian coordinate system to specify permeabilities and directions.
- cylindrical
- Use cylindrical coordinate system to specify permeabilities and directions.
- spherical
- Use spherical coordinate system to specify permeabilities and directions.
- direction_1_permeability (real) [=1]
- direction_2_permeability (real) [=1]
- direction_3_permeability (real) [=1]
- Permeability of the porous media in each of the three orthogonal principal axes. Used with constant type. These commands are valid only when permeability_type=cartesian. Also, these commands are equivalent to the previously used permeability array [={1,1,1}], which has been deprecated. AcuSolve will automatically map the permeability_array to the appropriate direction_1_permeability, direction_2_permeability, and direction_3_permeability parameters when reading an input file that uses the deprecated syntax. Note that if both parameters are specified, this mapping will cause the permeability to take precedence over the values that are specified for direction_1_permeability, direction_2_permeability and direction_3_permeability.
- cartesian_permeability_directions (array) [={1,0,0;0,1,0;0,0,1}]
- Orthogonal principal axes of the permeability values. The vectors are ortho-normalized prior to use. Used with constant type. This command is equivalent to the previously used permeability_direction [={1,0,0;0.1.0;0,0,1}]. Note that if both are specified in the input file, the one that appears last will be used for the computation.
- direction_1_permeability_multiplier_function (string) [=none]
- direction_2_permeability_multiplier_function (string) [=none]
- direction_3_permeability_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the permeabilities. If none, no scaling is performed. These commands are valid only when permeability_type = cartesian.
- radial_permeability (real) [=1]
- Radial permeability of the porous media in cylindrical and spherical coordinate systems. This command is valid only when permeability_type = cylindrical or spherical.
- axial_permeability (real) [=1]
- Axial permeability of the porous media in cylindrical coordinate system. This command is valid only when permeability_type = cylindrical.
- tangential_permeability (real) [=1]
- Tangential permeability of the porous media in cylindrical and spherical coordinate systems. This command is valid only when permeability_type = cylindrical or spherical.
- cylindrical_permeability_axis (array) [={0,0.0;1,0,0}]
- Principal axis of the axial permeability value. Other two principal axes in cylindrical coordinate are computed internally and ortho-normalized prior to use.
- radial_permeability_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the permeabilities. If none, no scaling is performed. This command is valid only when permeability_type = cylindrical or spherical.
- axial_permeability_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the permeabilities. If none, no scaling is performed. This command is valid only when permeability_type = cylindrical.
- tangential_permeability_multiplier_function (string) [=none]
- spherical_permeability_center (array) [={0,0,0}]
- Spherical center of permeability values. This command is valid only when permeability_type = spherical.
- darcy_coefficient (real) [=0]
- Coefficient of Darcy's (linear) term. Used with constant type.
- forchheimer_coefficient (real) [=0]
- Coefficient of Forchheimer's (quadratic) term. Used with constant type.
- darcy_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the Darcy coefficient. If none, no scaling is performed.
- forchheimer_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the Forchheimer coefficient. If none, no scaling is performed.
This command specifies a porosity model for the flow (momentum) equations. This model is only applicable to fluid element sets.
POROSITY_MODEL( "my porous media" ) {
type = constant
direction_1_permeability = 1.e-6
direction_2_permeability = 1.e-2
direction_3_permeability = 1.e-6
cartesian_permeability_directions = { 1, 0, 0 ;
0, 1, 0 ;
0, 0, 1 ; }
darcy_coefficient = 0
forchheimer_coefficient = 0.5
MATERIAL_MODEL( "my material model" ) {
porosity_model = "my porous media"
ELEMENT_SET( "fluid elements" ) {
material_model = "my material model"
is the
viscous stress tensor; and b is the
specific body-force. The Darcy-Forchheimer porosity model is used with type
constant. The porous media forces for this model are given
by:
where is the viscosity, given by the VISCOSITY_MODEL command; the index i refers to one of the principal orthogonal directions, given by the permeability_direction array; CDarcyand CForch are, respectively, the linear and quadratic coefficients of the porosity model, given by darcy_coefficient and forchheimer_coefficient; and Ki is the permeability in the principal direction i , given by permeability. The porosity for this model is Φ=1.
POROSITY_MODEL( "ramped Darcy coefficient" ) {
type = constant
cartesian_permeability_directions = { 1, 0, 0 ; 0, 1, 0 ; 0, 0, 1 ; }
darcy_coefficient = 1
darcy_multiplier_function = "ramped"
MULTIPLIER_FUNCTION( "ramped" ) {
type = piecewise_linear
curve_fit_vales = { 1, 0 ; 10, 0.5 }
curve_fit_variable = time_step
}POROSITY_MODEL( "ramped Forchheimer coefficient" ) {
type = constant
cartesian_permeability_direction = { 1, 0, 0 ; 0, 1, 0 ; 0, 0, 1 ; }
darcy_coefficient = 0.5
forchheimer_coefficient = 1
forchheimer_multiplier_function = "ramped"
}POROSITY_MODEL( "my porous media" ) {
type = constant
radial_permeability = 1.e-6
axial_permeability = 1.e-2
tangential_permeability = 1.e-6
cylindrical_permeability_axis = {0, 0, 0 ; 1, 0, 0 ; }
type = constant
radial_permeability = 1.e-2
spherical_permeability_axis = {0, 0, 0 ;
