Parameter Format
Each command may have zero or more parameters. Most command parameters have default values.
DENSITY_MODEL( "air" ) {
density = 1.225
expansivity = 0.0039
the value of the density parameter of the density model "air" is 1.225, the value of expansivity is 0.0039 and the remaining parameters have their respective default values.
- String
- Enumerated
- Boolean
- Integer
- Real
- List
- Array
