Parallel Timing Instrumentation
Due to the complexity and diversity of datasets, networks and file systems, it is often difficult to identify where problems may be occurring during parallel post-processing operations.
To understand how effectively AcuFieldView Parallel may be running for a given dataset in a given environment, detailed timing output for several common operations have been added. Timing summaries are available for the AcuFieldView client, the AcuFieldView server, or Controller server for AcuFieldView Parallel, and the worker server programs. Timings are further broken down to study the separate tasks reading data and creating surfaces.
