NodeRename ()
Rename a node in the data base.
Usage
NodeRename( path, newAddr )
path (string)
Data base path of the node.
newAddr (string)
The node new name.
Return Value
None
The path should be valid.
This routine changes the name of the node to a new name. The old name is given by path and the new name is given by newAddr. For example,
node = args
NodeRename( node + RS + oldName, node + RS + newName )
