AddMarker ()
Add a marker to the database for undo/redo.
Usage
AddMarker( tag, state = None )
tag (integer)
The tag that is added to the database.
state (tuple)
The information which is needed for refreshing the Undo action.
Return Value
None
The tag should be valid and exist.
This routine adds (puts) a marker to the database which is specified by tag. This tag is used for undo/redo mechanism. The information which is needed for refreshing Undo is given by state. For example,
changeInfo = ( item.name, )
AddMarker( tag = UndoTags.UNDO_TAG_NEW_GLOBAL, state = changeInfo )
