NewDb ()
Create and open a new data base.
Usage
NewDb( fileName, overwriteFlg = False )
- fileName (string)
- The name of the data base to be created.
- overwriteFlg (boolean)
- If this flag is True and an old data base with the same name exist, the old data base will be overwritten.
Return Value
None
None
NewDb( 'Db1' )
