Manufacturing Solutions
Moldex3D Shell Utility Menu
The Moldex3D Shell Utility Menu consists buttons that provide shortcuts to functionalities in HyperMesh. The layout of the buttons mimic the process flow required to set up a model for Moldex3D Shell.
The main Utility Menu is shown below, along with descriptions of each macro button.
moldex3D_shell_utility_menu
Tools
Midplane Wizard
Opens the Midplane Wizard tab, which contains a step-by-step procedure to set up a midplane injection molding input data. See the Midplane Wizard submenu.
Surfaces
Cleanup
Shortcut to the Edge Edit panel. This shortcut provides quick access to the Edge Edit, Defeature, and Point Edit panels for geometry cleanup operations.
Midsurface
Shortcut to the Midsurface panel, which provides tools to extract a midsurface from selected surfaces.
Lines
Create
Shortcut to the Lines panel, which is used to create lines.
Edit
Shortcut to the Line Edit panel, which is used to edit lines.
Generate Mesh
Shell Mesh
Opens the panel to generate surface mesh (tria).
Runner System Mesh
Opens the panel to generate 1D beam mesh for the runner
Coolant System Mesh
Opens the panel to generate 1D beam mesh for the coolant channel.
Model Setup
Create Property Cards
Opens a submenu for setting up the model. See Create Property Cards for details.
Diagnostics
Computes the element quality of the displayed solid elements.
Export
Opens the Moldex3D MSH Export dialog for exporting the model. See Export for details.
See Also:
Generate Mesh
Create Property Cards Submenu
Diagnostics
Moldex3D MFE Export
