Manufacturing Solutions
Generate Mesh
Generate Mesh
Generate Mesh
For Moldex3D Shell model setup there are three options for mesh generation.
generate_mesh_shell
Shell Mesh opens the panel to generate surface mesh (tria).
Runner System Mesh opens the panel to generate 1D beam mesh for the runner.
Coolant System Mesh opens the panel to generate 1D beam mesh for the coolant channel.
The elements for the runner system are displayed with the tag Runner. Similarly the elements for Coolant Channel are displayed with the tag Coolant Channel.
See Also:
Moldex3D Shell Utility Menu
