Manufacturing Solutions
Create Property Cards Submenu
The following image displays the Create Property Cards submenu.
create_prop_cards_submenu_shell
Assign Thickness
Opens a dialog to assign/extract thickness to part elements and organize them
Shell Mesh
Opens a selector for elements so that you can assign property cards for other surface meshes such as Moldbase, Mold insert and Part insert.
Create Runner
Opens a dialog so that you can create the runner system by specifying the geometrical parameters
Edit Runner
Opens a selector for elements so that you can select the elements that you want to edit the properties
Coolant Channel
Opens a selector for elements so that you can assign/edit the properties for coolant channel and heating rod
Points
Opens a selector for node so that you can assign property such as Fix Node, Sensor Node, Valve Gate Control Point Node and so on
BCs
Opens a selector for node so that boundary conditions such as Melt Entrance, Coolant Entrance and Coolant Exit can be defined on the node
<<<Back
Opens the main Moldex3D Shell Utility menu.
