Manufacturing Solutions
Shell Mesh
Shell Mesh
Shell Mesh
Using this option, properties are assigned to surface mesh other than the part, namely moldbase, mold insert and part insert. After clicking this button a selector for elements appears to pick the elements from the graphics. When the elements have been selected, the following dialog appears.
shell_mesh_dialog
For Moldbase and Mold insert surface mesh, a material needs to be specified. For Part insert surface mesh, material and thickness also needs to be specified.
Part_insert_surface_mesh
After clicking OK, elements will be moved to component collectors with names such MoldBase, MoldInsert and PartInsert. Properties will be created with the same names.
See Also:
Assign Thickness
Create/Edit Runner
Coolant Channel
Points
Boundary Conditions
