Manufacturing Solutions
Diagnostics
Diagnostics
Diagnostics
In this submenu, you can inspect the surface mesh quality of tria elements in terms of Aspect ratio and also plot thickness distribution.
diagnostics_menu_shell
Clicking on Show Quality Table displays the dialog shown below.
MX_1040_24
All the displayed tria elements are considered for aspect ratio calculations. The aspect ratio is defined as 2Ri/Ro , where Ri  is in radius of the triangle and Ro is the circumradius of the triangle. Click Show Elements to see elements that fall within the given range.
Clicking Plot Thickness plots the thickness distribution of the elements.
See Also:
Moldex3D Shell Utility Menu
