Manufacturing Solutions
Die Module Utility Menu
The Die Module Utility Menu contains macros available for the Die Module user profile of HyperForm. The panels provide shortcuts to the most commonly used features:
die_module_utility_menu_2
Create Lines
Line
Opens the Lines panel for creating new line data.
Fillet
Opens the Fillets panel, which is also located as a subpanel of the Lines panel, for creating fillets.
Line From Surface Edge
Opens the Lines panel with the from surf edges option selected.
Edit Lines
Combine
Opens the Line Edit panel with the combine option selected.
Extend
Opens the Line Edit panel with the extend line option selected.
Split
Opens the Line Edit panel with the split at point option selected.
Organize
Opens the Organize panel, where you can move entities from one collector to another.
Trans
Opens the Translate panel, where you can move entities in a single specified direction.
Rotate
Opens the Rotate panel, where you can rotate an entity around an axis in space.
Project
Opens the Project panel with the to plane option selected.
Intersect
Opens the Intersect panel with the elements option selected.
Create Surfaces
Spline
Opens the Prep Geom panel with the spline option selected.
Ruled
Opens the Prep Geom panel with the remove dent option selected.
Drag
Opens the Prep Geom panel with the rolling cylinder option selected.
Sweep
Opens the Line Drag panel.
Spin
Opens the Spin panel.
Skin
Opens the Skin panel.
Reflect
Opens the Reflect panel.
Edit Surfaces
2N Cut
Opens the trim with nodes subpanel of the Surface Edit panel.
Plan Cut
Opens the trim with surfs/plane subpanel of the Surface Edit panel.
Holes
Identifies holes less than a specified diameter.
Loops
Opens the untrim subpanel of the Surface Edit panel.
Delete
Opens the Delete panel, where you can delete various entities.
Dups
Finds duplicate surfaces and provides the option of deleting them.
Defillet
Detects surface fillets of a specified size range and provides the option of deleting them.
Untrim
Trans
Opens the Translate panel.
Rotate
Opens the Rotate panel.
Offset
Opens the offset subpanel of the Surface Edit panel.
Cleanup Surfaces
Toggle
Opens the cleanup subpanel of the Automesh panel with the toggle option set.
Equiv
Opens the edges subpanel of the Geom Cleanup panel with the equivalence option set.
Defillet
Replaces planar surface edge fillets of a specified size.
Trim-Int
Opens the edge fillets subpanel of the Edge Edit panel.
(Un)sup
Opens the edges subpanel of the Geom Cleanup panel with the (un)suppress option set.
Project
Opens the trim with line subpanel of the Surface Edit panel.
Quick Edit
Allows you to split surfaces and washers, change the category (shared, free, etc.) of edges, create or delete surfaces and points, project points, and trim fillets.
Prep Geom
Defillet edge
Opens the Prep Geom panel, Defillet edge page, where you can select to remove the ends defining the edge radius.
Fill cutout
Opens the Prep Geom panel where you can define lines and edges by two-node selection.
