Radioss to PAM-CRASH 2G Conversion Mapping
Elements
表 1. Supported Element Mappings
Radioss PAM-CRASH 2G
TRUSS BAR
BEAM BEAM
SPRING SPRING
SPRING+PROP/SPR_BEAM (TYPE 13) SPRBM
SH3N SHELL
SHELL SHELL
BRICK SOLID
TETRA44 TETRA44
ADMAS MASS
SPRING+INTER/TYPE2 PLINK
SPRING+PROP/KJOINT(TYPE33) KJOIN
RBODY RBODY
Boundary Conditions
表 2. Supported Boundary Condition Mappings
INIVEL INVEL
BCS BOUNC
CLOAD CONLO
Systems
表 3. Supported System Mappings
FRAME/FIX FRAME
SKEW/MOV FRAME
SKEW/FIX FRAME
Materials
表 4. Supported Material Mappings
M1_ELASTIC MAT_1D TYPE 201, MAT_2D TYPE 101
/PROP/SPRING MAT_1D TYPE 220
/PROP/SPR_BEAM MAT_1D TYPE 223
M0_VOID MAT_2D TYPE 100
M36_PLAS_TAB MAT_2D TYPE 102/103
M44_COWPER MAT_2D TYPE 102/103
M2_PLAS_JOHNS MAT_2D TYPE 102/103
Properties
表 5. Supported Property Mappings
PROP/BEAM PART, TYPE= BEAM
PROP/KJOINT PART, TYPE = KJOIN
PROP/SHELL PART, TYPE = SHELL
PROP/SOLID PART, TYPE = SOLID
PROP/SPRING PART, TYPE = SPRING
PROP/SPR_BEAM PART, TYPE = SPRING
PROP/SPR_GENE PART, TYPE = SPRING
PROP/TRUSS PART, TYPE = BAR
Curves
表 6. Supported Curve Mappings
FUNCT FUNCT
Control Cards
表 7. Supported Control Card Mappings
TITLE TITLE
  OCTRL/
/ANIM/DT DSYOUPUT
/TFILE THPOUTPUT
Components
表 8. Supported Component Mappings
PART PART
Contacts
表 9. Supported Contact Mappings
CNTAC36 INTER/TYPE7
Rigid Walls
表 10. Supported Rigid Wall Mappings
RWALL RWALL
Time History
表 11. Supported Time History Mappings
TH/SPRING THELE
TH/NODE THNODE
TH/FRAME THLOC
Sections
表 12. Supported Section Mappings
SECT SECFO
Groups
表 13. Supported Group Mappings
GRNOD/NODE GROUP
GRNOD/GENE GROUP
GRNOD/SUBSET GROUP
GRNOD/PART GROUP
GRNOD/MAT GROUP
GRNOD/PROP GROUP
GRNOD/GRNOD GROUP
GRNOD/SURF GROUP
GRNOD/GRSHEL GROUP
GRNOD/GRBRIC GROUP
GRNOD/GRSPRI GROUP
GRNOD/GRSH3N GROUP
GRNOD/GRTRUS GROUP
GRNOD/GRBEAM GROUP
GENOD/NODENS GROUP
GRNOD/FORMULA GROUP
Airbags
表 14. Supported Airbag Mappings
BAGIN MONVOL
