LS-DYNA to Nastran Conversion Mapping
Elements
表 1. Supported Element Mappings
LS-DYNA Nastran
*ELEMENT_MASS CONM2
*ELEMENT_INERTIA CONM2
*ELEMENT_BEAM CBAR
*ELEMENT_SHELL CTRIA3,CQUAD4, CQUAD8, CTRIA6
*ELEMENT_SOLID CTETRA4/CHEXA8/CPENTA6
*CONSTRAINED_SPOTWELD RBAR
*ELEMENT_PLOTEL PLOTEL
*CONSTRAINED_INTERPOLATION RBE3
*CONSTRAINED_NODE_SET RBE2
*ELEMENT_DISCRETE CELAS1
Properties
表 2. Supported Property Mappings
LS-DYNA Nastran
*SECTION_SOLID PSOLID
*SECTION_SHELL PSHELL
*SECTION_BEAM PBAR, PBARL
*SECTION_BEAM with ELFORM 1 is mapped to the PBARL property.
*SECTION_BEAM with ELFORM 2 is mapped to the PBAR property.
Materials
All the LS-DYNA materials are mapped MAT1 in Nastran.
Boundary Conditions
表 3. Supported Boundary Condition Mappings
LS-DYNA Nastran
*BOUNDARY_SPC SPC
*LOAD_NODE_POINT FORCE, MOMENT
*LOAD_SEGMENT PLOAD4
*INITIAL_TEMP TEMP
Coordinate System
表 4. Supported Coordinate System Mappings
LS-DYNA Nastran
*DEFINE_COORDINATE_NODE CORD1R
*DEFINE_COORDINATE_SYSTEM CORD2R
