Examples
   >>> from hw import mview
   >>> # Create bodies for Contact
   >>> b1 = mview.Body(name = 'moving', inertia_props_from_graphic = True)
   >>> b2 = mview.Body(name = 'static', inertia_props_from_graphic = True)
   >>> p1 = mview.Point(z = 50)
   >>> # Create graphics for Contact
   >>> g1 = mview.Sphere(origin = p1, body = b1, radius = 10)
   >>> g2 = mview.Box(itype = 'CENTER', origin = 'P_Global_Origin', body = 'B_Ground')
   >>> g2.setValues(lengthx = 50, lengthy = 50, lengthz = 2, align_pt1 = p1)
   >>> # Create 3D rigid contact and assign bodies and graphics
   >>> con1 = mview.Contact(b1 = b1, b2 = b2)
   >>> con1.setValues(ig = [g1], jg = [g2])
   >>> # Use Poission as the type of contact
   >>> con1.contact_type = 'POISSON'
   >>> # Set multiple values at once
   >>> con1.setValues(penalty = 1000, rest_coeff = 0.5)
   >>> # Get value of an attribute
   >>> con1.penalty
   1000.0
   >>> # Change the friction type to dynamic only
   >>> con1.coulomb_friction = 'DYNAMICS_ONLY'
   'DYNAMICS_ONLY'
   >>> # Assign static and dynamic friction coefficients
   >>> con1.mu_static = 0.6
   >>> con1.mu_dynamic : 0.3
